1997 Subaru Legacy Shift interlock and it won't start
146,000 MILES • 4 CYL • AWD • AUTOMATIC
MICKEY877
Need help, the car's battery died on a cold night back in Jan, since then it will not start and I could not even move it the shift lever would not move, it was locked and there was a clicking sound on the steering colunm when shift button was depressed. I looked in the manual and figured out it was the shift interlock and I over rode it to get it into neutral to move. Now it still will not start, is this shift interlock tied into another system? Every time the shift llocks up again and I need to insert screw driver to unlock per manual. Can this also prevent from starting? Have not been able to start for many weeks now and I am getting desperate. The shift interlock is $80 but I don't want to waste the $ if it may be something else, please advise, thanks you very much. Walter Edwards.. 201-652-3023
Mar 12, 2010 at 9:19 AM
KHLOW2008
  • 41,812 POSTS
Hi Walter,
Thank you for the donation.
The shift interlock requires the brake switch to be working to provide battery voltage to the shift interlock solenoid to enable you to shift out of park.
Check if the brake lights are comng on and if not, check the fuse first.
This should not be preventing the engine from being started and in order to understand what is wrong or missing, causing the non starting.
Check out this link for diagnostic procedures.
https://www.2carpros.com/kpages/first_things.htm
Mar 13, 2010 at 6:36 AM
