1997 Subaru Legacy fuel injection?
MUNXEES
  • 1997 SUBARU LEGACY
  • 4 CYL
  • AWD
  • 167 MILES
The car usually starts without touching the gas pedal. Yesterday I had to try twice then it stayed running fine. Today I had to try a few times, it finally started when I stepped on the gas quite a bit. However, it will not stay running when I remove my foot from the gas pedal. Any suggestions?
Thursday, April 16th, 2009 AT 3:10 PM
Check the coolant temperature sensor, idle air control valve and throttle position and mass airflow sensors.
Thursday, April 16th, 2009 AT 4:24 PM
MUNXEES
I spoke to the Subaru dealer service department. It ended up being that the car was flooded. Apparently, these vehicles have a fuel shut-off in the event the car becomes flooded. The remedy was to start the car and keep it running by holding the gas at a low idle until the flood is gone, at which point the car will take over and stay running. It took roughly about 10 minutes and the car revved a bit on its own and stayed running after that. Thanks for responding and I hope my solution helps others! Good luck!
Thursday, April 16th, 2009 AT 11:47 PM
