1997 Subaru Legacy Drive Belts
1997 SUBARU LEGACY
185,000 MILES • 4 CYL • AWD • AUTOMATIC
WEDGE1963
How do I go about removing the camshaft pulley so I can remove the drive belt cover? I do not have room nor an air supply for an impact drive and have already broken 2 strap wrenches. Thanks for any help you may be able to provide
May 27, 2008 at 2:22 PM
74XR7
  • 18 POSTS
There is an opening at the back of the motor, between motor and bellhousing. As you turn the motor over, you'll see a deal come around that's meant for a large screwdriver or other pry-bar type device to stick in and lock the engine in place (hard to decribe, obvious what it is when you see it). With the engine locked in place, put the socket on the bolt and whack the end of the ratchet with a hammer or some such to break it loose.
May 30, 2008 at 2:09 PM
