1997 Subaru Legacy check engine code P0743
18,300 MILES • 4 CYL • 4WD • AUTOMATIC
LYNNTOMFLY
  • 6 POSTS
Got code P0743, indicating "torque converter clutch circuit electrical." Looked at a couple of sites, including a Toyota site that indicated serious troubleshooting to determine if problem is ECM, shift solenoid valve, or harness/connectors.
Any suggestions?
I'm not into heavy maintenance, i.e., going into the transmission to check/change valve.
BTW, what's the ECM?
Many thanks!
Oct 1, 2009 at 9:26 AM
SERVICE WRITER
  • 9,123 POSTS
I would expect a high probablity of the the solenoid.
However if there has been work done that the harness was damaged, that can change things.
The ECM is the electronic control module AKA the "computer"....Powertrain control module...tamatoes, tahmahtoes...
Do you want testing procedures?
Oct 1, 2009 at 10:54 AM
LYNNTOMFLY
  • 6 POSTS
[quote:3a390b1c99="Service Writer"]I would expect a high probablity of the the solenoid.
Do you want testing procedures?[/quote:3a390b1c99]
Yes, please.
Thanks!
Oct 1, 2009 at 5:03 PM
SERVICE WRITER
  • 9,123 POSTS
I sent some info to your e-mail. If it is not there, check your spam folder.
https://images.2carpros.com/forum/automotive_pictures/30961_su_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_su1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_su2_1.jpg
Verify the flash codes, I think this will be #16
Oct 1, 2009 at 11:37 PM
LYNNTOMFLY
  • 6 POSTS
Many thanks.
Now I can talk intelligently with the transmission shop.
Oct 1, 2009 at 11:44 PM
