What cause the light to got on? Is there away to reset it?
Jan 9, 2008 at 12:12 PM
MIKE H R
MEMBER
the light is hooked up to your sensor in the brake fluid and the emergency brake. check the fluid in the brake resivor and fill if needed. on the emergency brake there is a switch that sometimes sticks. make sure the emergency handle is down all the way.
Jan 20, 2008 at 10:18 PM
