When the A/C is turned on and the engine is idling it blows cold air. As soon as the engine is revved both radiator cooling fans stop blowing and the high pressure switch cuts off the compressor. It resets after a couple seconds and then trips again. If I let the car come back down to an idle the cooling fans will come on again after about a minute and the compressor comes back on and the A/C starts blowing cold air again. What would cause the fans to shut off except when the engine is idling?
Jun 28, 2010 at 2:36 PM
