1996 Subaru Legacy white smoke
1996 SUBARU LEGACY
64,000 MILES • 4 CYL • AWD • MANUAL
MKOLWE
engine has not been running for one year.
changed oil.
started engine but experiencing white smoke especially on accelaration.
Feb 9, 2009 at 5:20 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If you are certain it is not condensation, white smoke from exhaust indicates a coolant leak into the combustion chambers. Normally caused by a cracked headgasket, allowing coolant to leak into engine and burn out exhaust. Check your coolant level and post results. I will follow up.
Thanks for using 2CarPros.com!
Feb 9, 2009 at 5:22 AM
