1996 Subaru Legacy Radiator? Valve?
150,000 MILES • 4 CYL • AWD • MANUAL
KIMKIM07
My water temp on dash is above red level and when I stopped I saw smoke from hood. It came from the left side and when I opened the hood, everything was wet on the left side, no sweet smell.
Oct 13, 2010 at 1:30 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if smoke was white than it was definitely coolant , you will have to find the source of the leak. could be water pump failure , hose failure etc...
Oct 13, 2010 at 1:52 PM
KIMKIM07
thanks, found a crack in the radiator. was fixed from previous owner and broke again, just going to replace it.
Oct 13, 2010 at 2:10 PM
