1996 Subaru Legacy over heating
DEEDEEBOO72
  • 1996 SUBARU LEGACY
  • 4 CYL
  • AWD
  • 111,000 MILES
1996 subaru it over heats and the heater goes hot than cold heat blows from the heater. The water is not circulating in the radiater when I remove the cap and look in the radiater. Any ideas on what is wrong and causing it to over heat. I did have a stereo system installed in my car.
Friday, October 30th, 2009 AT 12:06 PM
  • 109,867 POSTS
I would start with replacing the thermostat. It sounds like it isn't opening properly. Also, make sure the cooland it full and let me know if this helps.
Saturday, October 31st, 2009 AT 4:44 PM
CRZYDRVR
  • 432 POSTS
If the coolant is not circulating its a good indication that the water pump has failed.
Tuesday, December 8th, 2009 AT 11:56 PM
