1996 Subaru Legacy How can I check if my waterpump still ru
1996 SUBARU LEGACY
12,000 MILES • 4 CYL • 4WD • AUTOMATIC
LEBACO
hello, I want to check if my waterpump still runs proper. Just bought this car not formiliar with brand. After the car has been running water reservoir is full after few hours its half empty. It doesn´t overheat the engine according to the temp. meter.
Also there is a burned fuel smell with very light smoke coming from underneed the engine near the exhaust on the left top side of the engine. Is this a leak in the exhaust or fuel injectors etc.
Thanks you
May 10, 2010 at 1:12 PM
  • 31,937 POSTS
Hi there,
Get the cooling system pressure tested as this will locate any external leaks, as for the smell check that there is not a small oil leak from the rocker cover onto the exhaust heat shields, start here.
mark (mhpautos)
May 10, 2010 at 4:02 PM
