1996 Subaru Legacy engine studders when stopping
168,000 MILES • 4 CYL • AWD • AUTOMATIC
JHAPSTER
When slowing down from high speed to a stop light, the engine studders and sometimes stalls. Other than that it runs fine. We changed the plugs, plug wires and fuel filter and ran several bottles of injestor cleaner through. The engine light came on once with a code of lean mixture but the shop I went too had no idea what to fix other than the above. I'm thinking vacuum leak most likely in the advance system but thats a needle in a haystack and it runs fine at idle in the garage so there is no way to test hoses. is this a common issue?
Feb 2, 2008 at 9:51 AM
DONNA MURPHY
  • 5 POSTS
mine had same prob. spent $8000 trying to fix it then finally listened to my brother. i took out the mass air flow sensor, cleaned with fuel injector cleaner, dried and replaced. that improved it for awhile so i replaced the sensor and fixed the problem. we had it to 12 garages and every one said they didn't believe it was that sensor. i've talked to quite a few people who had the same prob.; they tried this and it was the sensor so i'm guessing it is pretty common.
Jul 1, 2008 at 6:07 AM
