1996 Subaru Legacy Engein runs hot
SUBARU23
Engine Performance problem
1996 Subaru Legacy 4 cyl All Wheel Drive Manual 150xxx miles
My engein was running hot so I replaced the thermastate and drained the radiator and put in all new fluid. The fans are all working. whats wrong?
Mar 7, 2008 at 10:45 AM
74XR7
  • 18 POSTS
Did you make sure to remove the air bubble that always forms in these engines when the fluid is drained? There's a screw on the top of the radiator, on the passenger side, to vent the air out. I usually open that and fill the engine thru it even though it's a tiny hole.
Mar 7, 2008 at 11:55 AM
