1995 Subaru Legacy Water Pump Installation
1995 SUBARU LEGACY
191,000 MILES • 4 CYL • AWD • AUTOMATIC
PUREHELLION
Is it possible for a water pump to be installed backwards in a legacy? before mine was replaced you could run the engine with the radiator cap off when checking it, now if the cap is off the coolant shoots out of the radiator like a gyser.
Aug 15, 2009 at 4:13 AM
  • 110,244 POSTS
No, you can't install it backwards. If the coolant is shooting out, it sounds like a bad headgasket. Was the car overheated prior to replacing the pump? Have you checked engine compression?
Aug 20, 2009 at 2:06 PM
