1995 Subaru Legacy shifter button
156,000 MILES • 4 CYL • AWD • AUTOMATIC
CLASSICAUTOCYCL
The shifter button sometimes won't go in, therefore not allowing me to get out of park. It was occassional at first, but now it's pretty regular. How do I fix it?
Sep 3, 2010 at 9:08 AM
BMRFIXIT
  • 19,053 POSTS
Two common possibilities
1- brake light switch
step on the brake and check if lights is on as they should if not suspect brake light switch and if need adjustment
switch is located on top by the brake paddle
2-Shift Lock Solenoid (A/T)
Located At base of shift lever
When stepped on brakes it should actuate and allow you to shift out of park
always check fuses 1st
check fuses
check fuse #1 ,2 and 12
Sep 3, 2010 at 11:07 AM
