Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Subaru
Legacy
Engine
Symptoms
Runs Hot
1995 Subaru Legacy engine runs hot
1995 SUBARU LEGACY
194,000 MILES • 4 CYL • AWD • MANUAL
MERTZB
MEMBER
1 POST
ar temp runs hot after replacing thermostat,
Radiator hoses and water pump replaced last year.
Jan 1, 2009 at 1:10 AM
MIKE H R
MEMBER
sometimes even new thermastats go bad. what i would do first is drain the coolant out then back flush the system good. Install a new thermastat and fill with coolant. the themastat could be binding up.
Jan 27, 2009 at 1:28 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
