1995 Subaru Legacy crank sensor
1995 SUBARU LEGACY
125,000 MILES • 4 CYL • 4WD • MANUAL
ROCKERYE
Where is the crank position sensor located? and what steps should be done installing a new one?
Feb 6, 2008 at 9:16 PM
VONKAISER2001
The crank sensor is located behind the serpentine belt directly on top of the the crankshaft pulley. Look for the electrical connector. Very easy to see from the front of the engine. Remove the plug, then the bolt, then gently pull the sensor staight out. Reverse to put new one in. Good luck
Feb 25, 2008 at 12:40 PM
