1995 Subaru Legacy Bucks/stutters at take off.
1995 SUBARU LEGACY
17,500 MILES • 4 CYL • 4WD • AUTOMATIC
KFLORES8306
I have a 95 Subaru legacy that stutters and bucks when I take off either at a stop light or stop sign. When I make turns, either left or right, it does it. I don't know what it means. You can feel it throughout the entire car. It's not a raddeling sound or a clacking sound. It's not getting the torque I guess you can say when I take off. Do you know what it could be or what it sounds like it could be?
Jul 16, 2010 at 8:36 AM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below:
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 16, 2010 at 2:54 PM
