1995 Subaru Legacy auto
1995 SUBARU LEGACY
135,000 MILES • 4 CYL • AWD • MANUAL
JOE ZUERLEIN
i have a1995 subrau legacy with a 2.2 engine here,s my problem when i let the motor idle for more 20 minites or so the temp gauge goes way up so i check the radiator cap it is not hot fans are working fine when i rev the engine up 2000 rpm the gauge starts to drop to normal range also when i drive up high mountain passes it does not overheat i had the coolant temp sensor replaced themostat replaced also and the water pump changed
Jun 17, 2008 at 6:31 AM
2CARPRO JACK
  • 11,533 POSTS
When the fans are on does it blow hot air? If not the t-stat could be defective, or some other flow restriction.Does it use coolant? no leaks in the system?
Jun 18, 2008 at 12:53 AM
KHLOW2008
  • 41,814 POSTS
Hi joe zuerlein,
Does switching the AC on and off repeatedly cause the gauge to move up quickly?
If yes, you have a poor ground for the gauge.
Jun 18, 2008 at 4:04 AM
