1994 Subaru Legacy intermittent problem starting
150,000 MILES • 6 CYL • AWD • AUTOMATIC
PATRICKC
On some days (mostly winter) our car fails to turn over. There is no clicking or other noise. The stereo and heater will work, but when I turn the key nothing happens. The check engine light has been on for 3 mos (we were told that the timing chain needs replaced), but we haven't fixed it as the mechanic said the cylinders had irreparable grooves and the car would die within a year (1-1/2 years ago.) Anyway, the part of the ignition where the key is inserted was taken apart and checked without resolution of the problem. Battery is new and strong. I'm guessing it is an electrical problem because if you wait a couple of minutes, it usually will fire up just fine. It seems to occur more as temps climb near the freezing mark and then drop over night?
Mar 19, 2009 at 5:13 AM
DREAKEN
Have you tried turning the key to the on position and manaully engaging the starter? If that starts the car, then the issue is in the wiring and likley not worth fixing.
But, on a prior Subaru I owned, had similar problem, never did fix it, just connected a manual start button to the starter (push button with two wire connectors) and never had another problem, it started every time (turn the key to on position and push the button).
Good luck.
Apr 4, 2009 at 3:42 AM
