1994 Subaru Legacy Check Engine Light
220,000 MILES • 4 CYL • FWD • AUTOMATIC
RICK2100
The Check Engine Light has been on in my 94 Subaru Legacy wagon for some time now. I have tried to go by Autozone, Oriely's, etc to have them check the codes for me but their fault readers are not designed to connect to a car as old as mine. Can anybody tell me what kind of connection I have and where to find a fault reader that will connect to it. Even the local Subaru dealer did not have anything for my vintage of car. The port I am trying to connect to is located under the dash on the right hand side of the driver's side. If this is the wrong port does anyone known where the correct one is?
Jan 14, 2009 at 5:22 AM
DOCFIXIT
  • 18,828 POSTS
You have an OBDI system and it was replaced by OBDII in 1997. If you can find a shop that's be around a while they may have scanner. If not they can be bought for $40 to $60. Click on car parts site at bottom of reply.
Let me know
Thanks for donate
Jan 14, 2009 at 5:43 AM
RICK2100
Am I looking at the correct port to plug the OBD1 scanner into? The port I am looking at is on the far right of the drivers side under the dash.
Jan 15, 2009 at 3:00 AM
DOCFIXIT
  • 18,828 POSTS
Near heater black 4 terminal
Have you found an OBDI scanner?
Jan 16, 2009 at 3:01 AM
