I am trying to replace the starter?
1993 SUBARU LEGACY
TARILYNS
Engine problem
1993 Subaru Legacy Engine Size unknown All Wheel Drive Automatic
I am trying to replace the starter in a 1993 Subaru Legacy and cannot determine the size of the bolt that holds it in place. Can you tell me what size socket I need to use to remove it?
Thanks,
Terri
Dec 15, 2007 at 1:08 PM
  • 31,937 POSTS
Hi there,
They will be metric and i would think that they will be 14mm or 17mm
Mark (mhpautos)
Dec 15, 2007 at 1:34 PM
  • 55,224 POSTS
For the 1993 Subaru Legacy, the bolts that hold the starter in place typically require a 14mm socket. There are usually two bolts securing the starter: here is how the change the starter out with the location as well. Please check out this video
https://youtu.be/xthr-PWBvF4?si=1ub3LHG_KwMWL50H
Let us know if you need anything else.
Oct 30, 2024 at 10:51 AM
