1993 Subaru Legacy Please Help
1993 SUBARU LEGACY
200,000 MILES • 4 CYL • AWD • AUTOMATIC
KPELL
Yes, I am having a little problem with my car. It is a 93 Subura Legancy. The car will idle fine until I put it in gear and when I mash the throttle it will hestitate and stumble. The mechanic checked the fuel pressure it is about 25 and is supposed to be 36. We have put 2 fuel pumps on it so we know that's not the problem. Could it possibly be the fuel regulator. It has new plugs and wires also. The mechanic thinks maybe the timing and of course that is more to get into than your thougt. I drive the car for delivering the mail. If you could possibly give me a thought. Thanks!
Mar 11, 2008 at 10:16 AM
MASTERTECHTIM
  • 4,750 POSTS
if you crimp the fuel return line you should see a drastic increase in pressure. if you do then replace the fuel pressure regulator, if it stays the same you must find why pump keeps failing.
Mar 11, 2008 at 10:39 AM
