1993 Subaru Legacy hesitation with hard accelaration
1993 SUBARU LEGACY
180,000 MILES • 4 CYL • AWD • MANUAL
SUBARULEGACY
This car recently developed a misfire like symptum while applying a hard accelaration in lower rpms.
It has a new set of plugs and fuel filter. What do I do to fix it? Thank you for your help.
Matt
Apr 29, 2010 at 2:41 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Apr 29, 2010 at 6:44 PM
