Engine Mechanical problem
1993 Subaru Legacy 4 cyl Two Wheel Drive Manual
I just replaced the heads .When I went to replase the timing belt I wanted to double check that #1 was tdc. AS i started to rotate the crank it stopped and won't turn foward or backwards . I was told that this year was a non interferance.Confused
Feb 8, 2009 at 4:45 AM
