1992 Subaru Legacy You might have fun with this one....
1992 SUBARU LEGACY
MASTERPEACE
Transmission problem
1992 Subaru Legacy All Wheel Drive Automatic 199000 miles
I bought this car from a friend. I helped him put in a used tranny because the old one went bad. The newer tranny appears to be the same, supposedly with the same gear ratio as the original. This was purchased from someone a few hundred miles away by my friend. I believe the transmission came out of a wrecking yard somewhere.
At any rate, this car, in all wheel drive, has problems. Only in all wheel drive. It will suddenly yank to one side, usually the left side, will act as though you are going thru mud(for lack of a better explanation), and today when I put it back into all wheel(I've been in front wheel for a couple of weeks, but winter is coming), it was worse than before. Now it also whines, and the power is not there. Putting it back into front wheel drive gave me the power back.
We had the CV joints both replaced by a mechanic who told us they needed it. This did not solve the problem. The mechanic is fairly sure that this is a "3rd solenoid" problem within the tranny. He has not done that particular work before. And he is a bit hard to get ahold of.
I just need to know where the problem most likely lies, and if you have any idea, on what a potential cost would be for parts.
I appreciate any help you can give. The car does run good in front wheel drive. I had a 1991 legacy prior to this one; it ran perfectly. It was one though, that I sold for financial reasons.
By the way....this car in all wheel drive typically acts up in the speed range of 30-40 mph, and mostly with the tach between 2200-2700 rpms. Although it had started to go beyond that just before I put it into all wheel drive. Obviously, with snow coming in the pacific northwest, I cannot leave this in all wheel in its current condition. That would be an accident in the making.
Thanks,
Dave
Oct 28, 2009 at 4:28 PM
KHLOW2008
  • 41,814 POSTS
Hi masterpeace,
Thank you for the donation.
From the symptoms description, the most likely place to check would be the differentials, seems it is malfunctioning and causing the problem.
The whining noise is an indication there could be lack of lubrication. If the noise is coming from the rear and is not present, the rear differential could be the cause of it.
Were the differentials oil checked? The front differential oil is separate from the auto trans and was it refilled when doing the trans replacement?
Was the rear differential oil checked? As problem was similar, I believe this should be the item that you need to look at.
Sorry i am not able to provide you with the costing and maybe you could check with the place that you bought the trans for a used unit.
Oct 29, 2009 at 5:46 AM
