So when getting off the highway the other day, i depressed the brake, as I did there was a loud clunk from the back right wheel and the brake pedal went all the way to the floor.... As i coasted off the exit, at lower speeds there began a loud grinding coming from the back right wheel... I still had the ability to brake you just need to pump the brakes in order to gain pressure on the pedal.... when i reached my destination... i jacked the car up and popped off the wheel...there was no leaking fluid (from anywhere including the back right brake)...the pads are old and it was obvious from the presence of rust and lack of wear on the rotor that they need to be desperately changed...however...i have never heard of that causing a sudden loss of braking power...is it possible for a brake pad just to rust out?...or is it something else like the caliper?
Feb 18, 2010 at 4:55 PM
