1992 Subaru Legacy Fuel Filter
1992 SUBARU LEGACY
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
BARRYFLY
How do I change the fuel filter on a 1992 Suburu legacy station wagon?
Jan 5, 2009 at 7:34 AM
MIKE H R
  • 3,094 POSTS
the fuel filter is located under the hood by the brake resevoir. With engine off loosen the output hose to release pressure, be careful it is under high pressure. After the pressure has been released loosen both lines. tag the inlet hose so you know whicjh one comes from the tank so it can be put back on correctly. then loosen the clamp that hold the filter in place. The filter is big black round with the two hoses comming out of the top. Remove filter and replace,
Jan 27, 2009 at 1:12 AM
