1991 Subaru Legacy Oil Leaks
175,000 MILES • 4 CYL • 4WD • MANUAL
SHOKARTA
Hi there... my car had a oil leaks from the pump... already fixed but the problem was around 4months... so everywhere i have a oil dirtness on the ground... and cant remove it :(. Do u know something how can i remove the oil dirtness from the all surfaces of the ground?
thanks u
Jan 13, 2008 at 7:28 PM
  • 31,937 POSTS
Hi there,
You can use a dry "Kitty litter" clay base oil absorbotion mixture. leave it on the stain and over time it will suck out the oil, (on good if it gets wet), there are also wash down type oil stain removers , your parts store will have a good range to choose from.
Mark (mhpautos)
Jan 13, 2008 at 7:39 PM
