I changed my thermostat in my car because it was overheating. Well it is still overheating, what else can I do?
Tuesday, October 28th, 2008 AT 12:47 AM
BLUELIGHTNIN6
MECHANIC
Your radiator could be bad. Is there any leaks? The electric fans in front of radiator should be kicking in. Make note of that when you inspect the radiator for leaks. The head gasket may have a crack, or the head itself could be cracked which would most likely result in water leaking into your oil, so check your oil.
