1990 Subaru Legacy missing
AIWWNW
Engine Mechanical problem
1990 Subaru Legacy 4 cyl Front Wheel Drive Automatic
engine missing, also headlights seem to blink while idling but when u press the acc. the lights brighten up. Has new Alt/battery. Also no power going up hill.
Feb 12, 2010 at 8:17 PM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Feb 12, 2010 at 9:24 PM
