1990 Subaru Legacy Brake fluid leak
1990 SUBARU LEGACY
CARNEYBAR
Brakes problem
1990 Subaru Legacy 4 cyl Four Wheel Drive Automatic not su miles
An ongoing problem recently gotten worse. Used to be once every six months brake fluid would leak a little below line of refill container located under hood. Once road it for few days to the point where brakes went out...added fluid and had a lot fo air in the line...brakes would go to floor. Now, brakes work fine, but fluid is low everyday as opposed to once a month, then once a week. Not by a lot, but enough to trigger the light indicator inside the car to notify me. I will always fill it up to the line before driving, but get in car next day and is a little low and light is on again. Brakes still work fine, as a matter of fact, a year ago, had front and back pads put on. Is this going to be expensive or life threatening? Could it be a seal or a line, or master cylinder?? Please advise getting desperate. Thanks, Barbara C
Nov 14, 2009 at 7:35 AM
CARNEYBAR
I requested information or help in solving a simple problem with my car and absolutely no one responded in two months.
Thanks a lot for all your help!!!!!!!!!!!!
Jan 3, 2010 at 8:35 AM
