1998 Subaru Justy parking/tail lights on
1998 SUBARU JUSTY
STEVEEEEB4
Electrical problem
1998 Subaru Justy 4 cyl All Wheel Drive Automatic
parking / tail lights remain on even with key off ,,, even after 15 minutes,,, have to disconnect the fuse,,, ??? probably some kind of relay , ?? what and where is it located/ thanks, steve b.
Oct 26, 2010 at 5:32 AM
LEGITIMATE007
  • 5,121 POSTS
check behind the brake pedal for the brake light switch, it may be stuck or faulty, a replacement should fix you right up.
Oct 27, 2010 at 2:10 AM
