2004 Subaru Impreza Power steering stiff at times
62,345 MILES • 4 CYL • AWD • MANUAL
UNIC66
  • 8 POSTS
I had the power steering bracket replaced without removing the pump.
The mechanic brought the car back with the power steering making noises and getting stiff intermittently.
I immediatley popped the hood and inspected the tension on the belt.It was overtightened!
Could the tight belt have damaged the power steering pump and caused my symptoms?
I never had any problems before this mechanic worked on my car at his house!
Thanks,in advance!
Dec 16, 2008 at 10:43 AM
CRZYDRVR
  • 432 POSTS
if the belt was over tightened it could has damaged the pump bearing.
Feb 22, 2009 at 6:47 PM
UNIC66
  • 8 POSTS
It was the bearing!I replaced th pump and that solved my problem!Thanks for your input.
Feb 23, 2009 at 4:52 AM
