2002 Subaru Impreza performing a compression test on my wrx
140,000 MILES • 4 CYL • AWD • MANUAL
JDWRX
  • 12 POSTS
i am going to be doing a compression test on my car, but i dont know how i would go about disabeling my fuel system? i looked for some kind of fuse that i could disconnect for the fuel pump, but couldnt find one.
Mar 23, 2008 at 5:04 AM
MASTERTECHTIM
  • 4,750 POSTS
can you access the injector plugs and unplug them? get back to me
Mar 23, 2008 at 5:19 AM
JDWRX
  • 12 POSTS
The thing with doing that, is that it is pretty hard to get to the injectors in this engine. i was hoping there was an easier way to do it.
Mar 23, 2008 at 6:12 AM
MASTERTECHTIM
  • 4,750 POSTS
how about unplugging fuel pump. i just looked for fuse to pull and i cant find one just a main relay
Mar 23, 2008 at 10:39 AM
JDWRX
  • 12 POSTS
would that be located in the fuse box in the engine bay or the one inside the car? do you know what the relay is labeled as?
Mar 23, 2008 at 10:55 AM
MASTERTECHTIM
  • 4,750 POSTS
hang tight. im going to try to download a picture for you. this might take a few minutes.
Mar 23, 2008 at 11:02 AM
MASTERTECHTIM
  • 4,750 POSTS
this is the weirdest fuse to find. there is no fuel pump fuse in under dash fuse paqnel and under hood fuse panel. look in the rear cargo area on passengers side for the fuel pump module. this is going to be the easiest thing to find, and disconnect it.
Mar 23, 2008 at 11:25 AM
JDWRX
  • 12 POSTS
well i did what you said, i had to take out my back seats to get to the clip, but it wasnt too bad. thank you for all your time and help, i really appreciate it.
Mar 23, 2008 at 3:00 PM
