2002 Subaru Impreza engine misfire code
125,000 MILES • 4 CYL • FWD • MANUAL
COACHBOB
I have a misfire code in cylinder #3. I am not sure which cylinder this is. I used a scanner to diagnosis this so far. I replaced the plugs with double platinum plugs. The engine will run fine except at near full throttle when it will misfire and buck. possible coil on plug, but the dealer seldom sees this issue. I was thinking possible injector, but it feels like ignition. I think #3 is right rear, near the turbo and possibly causing the coil to break down, but still possibly injector coil breaking down. Any ideads? Thanks.
Mar 6, 2008 at 6:33 AM
  • 75,988 POSTS
Inspect and Test the injector and do a compression test on that cylinder-
Mar 6, 2008 at 6:36 AM
