2002 Subaru Impreza Car smells like gas
2002 SUBARU IMPREZA
57,000 MILES • 4 CYL • AWD • AUTOMATIC
CKSWIFT
When i have the heater on or defrost on and the car is on idle the car smells like gas. What's the problem?
Thanks
Dec 28, 2008 at 8:33 AM
CORMAYK
I have a 2002 Impreza WRX with the same problem. When you first put on the heat you get blasted with gas fumes for about 5 min or so, then it goes away. I was told that it is a design flaw for this particular year and they fixed it for the 03 models. Two parts need to be replaced in order to fix the problem, however it isn't a recall item so you'll have to pay for it. Apparently it's a pretty common problem for 02 models.
Apr 28, 2009 at 1:46 PM
