1999 Subaru Impreza Engine oil seen on tailpipe
69,000 MILES • 4 CYL • FWD • MANUAL
MUIGAI
I recently observed oil coming from my tailpipe. I traced it to one of the cylinders. Oil is also seen to leak from one of the engine breather pipes. Where is it coming from and what do i need to do to fix it? I add about 500ml of oil every 1000miles, in between service
Also, my engine hesitates to rev up from a stop. I have to rev it first.
Kind regards,
Peter
Jan 5, 2009 at 8:43 PM
ARC_55
  • 66 POSTS
What cylinder is it coming from? I would do a compression test and find you issue. Sounds like you hav excessive engine blow by due to an internal issue.
Mar 2, 2009 at 12:18 PM
MUIGAI
It comes from the forward cylinder on the right. (looking at it frm the drivers seat). I will have a compression check done to narrow down the problem. Thanks
Mar 3, 2009 at 8:40 PM
