1998 Subaru Impreza turbo
1998 SUBARU IMPREZA
SUBARU TURBO
  • 18 POSTS
Engine Mechanical problem
1998 Subaru Impreza 4 cyl All Wheel Drive Manual 65.000 miles
I have just brought a new turbo for impreza, r reg. apart from the turbo, what else do i need??? the turbo turbine gaskets? thats it. just answer straight answer what i want. thanks.
Jul 11, 2009 at 7:50 AM
KHLOW2008
  • 41,814 POSTS
Hi subaru turbo,
Thank you for the donation.
You would need the following.
1. Exhaust manifold to turbo unit gasket.
2. Turbo to exhaust pipe gasket.
3. Lubricating oil pipe gasket.
4. Most likely you would need the return hose, tends to harden and cracks when removed.
5. Rust penetrant to spray onto the nuts for smooth and easy removal.
Good luck.
Jul 11, 2009 at 9:42 PM
