1998 Subaru Impreza fuses
SUBARU TURBO
  • 1998 SUBARU IMPREZA
Steering problem
1998 Subaru Impreza 4 cyl All Wheel Drive Manual
cud u answer please, looking for any fuse. Just like to know if car has to be running or not. Or when does it.
viberates over a speed about 60mph
Friday, September 19th, 2008 AT 3:46 AM
2CARPRO JACK
  • 11,533 POSTS
Hard to answer when you arent specific about what you want. Any fuse? There is a fuse block behind the left side of the dash, one in a power center under the hood, where you will also find a relay block. Some need the key on to get power and some have power all of the time
Vibration. Have the front suspension checked, could be worn ball joints or tie rod ends that make it vibrate at speed.
Friday, September 19th, 2008 AT 7:42 AM
