1998 Subaru Impreza dump valve
1998 SUBARU IMPREZA
SUBARU TURBO
  • 18 POSTS
Engine Performance problem
1998 Subaru Impreza 4 cyl Four Wheel Drive Manual
Hi
i have a dump valve for subaru impreza, where do i fit , how do i , etc etc
Jan 30, 2009 at 7:34 AM
KHLOW2008
  • 41,814 POSTS
Hi subaru turbo,
Thank you for the donation.
Here is a description of the DUMP VALVE
Dump valves are fitted to the engines of turbo charged cars and sit between the turbo outlet and the throttle body. When transitioning from a boosted state to a closed throttle state (as in between shifts), due to inertia, the turbo continues to pressurize air, but the closed throttle prevents the compressed air from entering the engine. In this case the pressure exceeds the preset spring pressure in the dump valve and the excess pressure is bled off to atmosphere.
Even with a dump valve the compressed air acts as a brake on the turbo (slowing it down), because the pressure on the backside of the turbo is at a higher pressure than on the front side (and the air actually wants to flow through the turbo backwards).
A blowoff valve is a more elegant solution to this problem by allowing the turbo to "freewheel" when the throttle is closed (equalizing the pressure on both sides of the turbo). Unlike a dump valve a blowoff valve can be used at multiple boost settings without reconfiguration.
Blowoff valves are sometimes incorrectly called dump valves because they serve a similar function, but they are very different solutions to the same problem.
To install this item, you need to remove the hose between the throttle body and turbo unit, cut the hose and install the valve in between. Simple job but the hose a not a cheap item and once cut, you cannot reuse without replacing it.
Jan 31, 2009 at 4:31 AM
