1998 Subaru Impreza CVC Boot-Axles
1998 SUBARU IMPREZA
14,300 MILES • 4 CYL • AWD • AUTOMATIC
BRIEN
I had a CVC Boot tear and leak grease. I put in more grease and a patch until I could afford a proper fix. The car operates fine. I am going to replace the Sub-Axle on that side. (Passenger Side). Is there anything else you would reccomend?
Apr 29, 2010 at 7:12 AM
MERLIN2021
  • 17,250 POSTS
You put a patch on the boot? This does not usually work...the convolutions on the boot force grease back into the joint as you drive, if they are deformed, the joint wont be properly greased, and could fail sooner.
Apr 29, 2010 at 7:22 AM
