1998 Subaru Impreza clutch
135,000 MILES • 4 CYL • AWD • MANUAL
BANKS4777
My clutch was feeling soft the other day, so I tightening the clutch cable. Then I went to try it and it would not engage. I tried lossening the cable and adjusting it back and it still wouldn't engage any gears. Are there any tests I can run to find out what might be the issue here. Thank You
Mar 24, 2009 at 5:37 AM
ARC_55
  • 66 POSTS
clutch cable? I was not aware of any clutch cable on these later years of subarus.
This is not a full hydraulic system?
If it is i would peel back the clutch master cylinder under neath the dash and look for fluid going past the seal. I would also inspect the slave the same way as the master, followed by flex lines, hardlines, fittings for any possible leaks. If there is a leak this means you have drawn in air into the system causing a poor pedal.
Also check clutch fluid level in the resivior. If there is a leak it will need to be fixed and the system reblead of any possible air.
Apr 1, 2009 at 10:10 AM
