1998 Subaru Impreza boost gauge
SUBARU TURBO
  • 18 POSTS
Engine Mechanical problem
1998 Subaru Impreza 4 cyl All Wheel Drive Manual
HI
Ive had a subaru impreza before same year and reg ( r) on old car started enginge and boost gauge went to 0, which im sure is wright, as my mate has boost gauge.
NOW when i tried to connect to the pressure outlet, thats a spare 1 ,blocked off. it reads! - 0.5 HELP...
what can i do so it reads like it should... when i start. 0.
Apr 18, 2009 at 6:00 AM
KHLOW2008
  • 41,812 POSTS
Hi subaru turbo,
Thank you for the donation.
If meter is installed after the throttle plate, it would show a negative reading as during idling when there is no boost, the manifold would have a vacumn.
In order to have zero boost or vacumn, the meter should be connected just before the throttle plate on the air hose.
Apr 19, 2009 at 12:47 AM
