Hi cilantro211,
It could be the clutch. It works intermittently because there is a pressure leak and if you accelerate hard, the clutch does not have time to engage fully resulting in the slippage.
You ought to check the ATF level and cdondition first. If the ATF filter is clogged, it might also cause the problem.
It could be the torque converter causing the problem too, so you need to test the line pressures to find out more.
SPONSORED LINKS
Friday, June 27th, 2008 AT 8:19 AM
