1997 Subaru Impreza radiator
165,450 MILES • 4 CYL • AWD • AUTOMATIC
DRNAD
antifreeze keeps going into overflow tank. engine dosen't get hot. someone told me it was the head gasket doing it. Is this true?
Nov 28, 2008 at 8:38 AM
ARC_55
  • 66 POSTS
you need to do a coolant combustion leak test. Its a dye that tells you if there is combustion gasses leaking into you cooling system. Head gaskets are very common on subarus so i am not suprised. A leaking head gasket will put excessive pressure into the cooling system and push the cooling up and out or in the overflow.
Mar 2, 2009 at 1:07 PM
