1997 Subaru Impreza motor fan
1997 SUBARU IMPREZA
253,849 MILES • 4 CYL • 4WD • MANUAL
ABDULMONAEM
i have subaru impreza 1997.my motor fan in radiator is not working when i switch to ON but when ACC its working.before this happen i went to mechanics then removes the connection to sensor to prevent overheat i have been used for 1 month till this problem comes. fuses and relays are ok I have Checked all by using VOM(VOLTMETER).
Mar 7, 2009 at 1:14 AM
MARKM33
It's probably the temperature switch. I have the same problem right now and am just looking around for where the damn switch is located. The switch costs about $15.
Mar 8, 2009 at 11:28 AM
