1997 Subaru Impreza Fuel Pump Issue
SUBARUKIFER
1997 Subaru Impreza 4 cyl All Wheel Drive Manual
My Subaru sputters, and then the engine dies. the check engine light does not come on. I had the fuel pump, the spark plugs, and the fuel filter replaced.
Apr 4, 2008 at 6:15 AM
  • 75,988 POSTS
Get the fuel pressure check and if its producing the correct pressure-troubleshoot the ignition system could be the coil/s, distributor pick up coil, ignition control module/ignitor/cam and crank sensors and computer- Try doing below to find out what's missing
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
Fuel pump and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Apr 4, 2008 at 8:50 AM
