1997 Subaru Impreza engine problem
214,000 MILES • 6 CYL • AWD • AUTOMATIC
SDUBOIS22
My car over heated so i changed the radiator and the thermostat.. When I started my car antifreeze started leaking from above my thermostat where the engine casing is. I was wondering if I might of put the thermostat in backwards or if my engine casing can have sealant around it to hold in the antifreeze?
Dec 28, 2009 at 10:24 PM
  • 110,251 POSTS
Remove the housing and make sure the t-stat is in straight. Let me know if you have other questions.
Jan 27, 2010 at 12:28 AM
