1997 Subaru Impreza battery swap
166,696 MILES • 4 CYL • AWD • MANUAL
AVTECHCT
i just changed my battery to a new one
NOW the "park "and tail lights do a blink when the engine is off or on for that matter.
there is supposed to be a RESET button under the
dash on the driverside.
i found this black button pressed it no luck .....whAT DO I DO to stop this
Mar 8, 2008 at 7:34 AM
  • 75,988 POSTS
Couldn't find a reset button-looked all over -try checking the tail/illumination relay in the fuse/relay box in left side of engine compartment could be sticking.
Mar 8, 2008 at 8:06 AM
MASTERTECHTIM
  • 4,750 POSTS
ok you have a aftermarket alarm. with the key off push and hold the black button then turn key on this should fix it. let me know if you have any more problems
Mar 8, 2008 at 9:10 AM
2CARPRO JACK
  • 11,533 POSTS
Or for factory alarm, try locking and unlocking the drives door with the key
Mar 9, 2008 at 12:49 AM
