1995 Subaru Impreza speedo
1995 SUBARU IMPREZA
255,119 MILES • 4 CYL • AWD • AUTOMATIC
INKINWOOD
my speedometer doesn't work,i have checked all fuses and none look bad,what could be causing this and how do i fix it?
Oct 6, 2008 at 3:25 PM
KIPEY84
  • 7 POSTS
ive had this problem youll have to take the whole cluster out and on the backside is the cable that hooks directly up to it...little bit of a pain but check and see if its still connected (mine wasnt) if it is check it on the transmission side...you should be able to find some pics found mine on a forum (25rs.com)
Oct 14, 2008 at 12:50 PM
INKINWOOD
i will try that,thank you.i wasn't sure if it had a cable or if it was electronic,can't find a repair manuel anywhere either.
Oct 15, 2008 at 7:00 AM
KIPEY84
  • 7 POSTS
check 25rs.com thats where i found it...search for it at the top theres a link...should find a diagram
Oct 15, 2008 at 12:04 PM
